Eine GL 300A Funke, die erfolgreich mit Firmware v1.3.20 oder höher upgedatet ist, ist nun eine GL 300B und kann nicht mehr mit einem USB Stick beglückt.. ehm. upgedatet werden!
Issues on updating the remote controller and corresponding Solutions
GL 300A:
Please try to update GL300A remote controllers by using a USB drive/ SD card adapter or connecting the aircraft gimble port with the controller via a USB cable. If you fail updating with these two methods, please connect your controller with your app (meanwhile keep the aircraft off and keep your mobile device connected with the Internet), then turn on your app, go to camera-aircraft status, download and install the firmware and the remote controller will be updated (More than 15 remote controllers in China have been updated in this way).
GL300B:
Remote controllers whose model type is GL300B can only be updated on your app, however, according to the survey, the updates failed in the following three conditions:
First, The remote controller turns off automatically, then the first led light on it turns cyan. And when you connect your remote controller with your mobile device again, the app says no signal, and there’s no notification that says the remote controller needs to be updated.
Solution: It’s possibly because the 1765 module on the remote controller fails updating. So please press these four buttons on the remote controller at the same time, namely, C1, C2, Recording and the Scroll that adjusts ISO, meanwhile, spare another finger to turn the remote controller on (don’t let the other four fingers go), then turn on the app and you’ll be able to download the firmware again and please follow the steps on the app and the remote controller will hence be updated. This is a update reset. (More than 10 remote controllers in China have been updated in this way).
Second, the app fails updating the remote controller and the first led light turns red.
Solution: please update on your app again. (More than 2 remote controllers in China have been updated in this way).
Third, the remote controller won’t update any ways.
Solution: the 1.2.0 Android app has this bug that no matter your firmware is latest or not, the app will ask you to update the remote controller. The new DJI GO Android app will solve this bug. (Many more remote controllers in China have been updated in this way).
Probleme beim updaten der Funke - Lösungen
Gehe zu
- INFO
- ↳ Information
- DJI Kopter
- ↳ Phantom 1
- ↳ Phantom 2
- ↳ Phantom 2
- ↳ Phantom 2 Vision
- ↳ Phantom 2 Vision+
- ↳ Phantom 3
- ↳ Phantom 3 Standard
- ↳ Phantom 3 Advanced & Professional
- ↳ Phantom 4
- ↳ Inspire
- ↳ Inspire 1
- ↳ Inspire 2
- ↳ FlameWheel F330 / F450 / F550
- ↳ FlameWheel F450 / F550
- ↳ Spreading Wings S800, S900, S1000
- ↳ DJI - betrifft mehrere Systeme
- ↳ Matrice 200
- ↳ Matrice 600
- ↳ Mavic
- ↳ Spark
- ↳ DJI Neuheiten
- ↳ DJI Racing Drone
- Yuneec Kopter
- ↳ Q500 Serie
- ↳ Q500
- ↳ Q500+
- ↳ Q500 G
- ↳ Q500 4k
- ↳ ST10 , ST10+
- ↳ Tpyhoon H
- ↳ Sonstige Yuneec Kopter
- Racer
- ↳ Emax Nighthawk
- ↳ Andere Hersteller
- Gaui Kopter
- ↳ Gaui 840H
- ↳ Andere
- Graupner Kopter
- ↳ Graupner Alpha 250Q mit GR-18 FC
- ↳ Graupner Hornet 250 Tricopter mit GR-18 FC
- ↳ Graupner Sweeper Droneball
- drone-hacks (dji)
- ↳ English area - https://drone-hacks.com/
- ↳ General Chat
- ↳ Mod Client
- ↳ Tips & Tricks
- ↳ Feature Requests
- ↳ Drone Model specific
- ↳ Mavic
- ↳ Mavic 2
- ↳ Mavic 2 Enterprise
- ↳ Mavic Air
- ↳ Mavic Air 2
- ↳ Mavic mini
- ↳ Sparc
- ↳ Phantom 4
- ↳ Phantom 4 pro v2.0
- ↳ Inspire 2
- ↳ Inspire 1 / Phantom 3
- ↳ Other
- ↳ Global Hawk
- ↳ Deutschsprachiger Bereich - https://drone-hacks.com/
- ↳ Allgemein
- ↳ Mod Client
- ↳ Tip's & Tricks
- ↳ Gewünschte Erweiterungen
- ↳ Vom Kopter Model abhängig
- ↳ Mavic
- ↳ Mavic 2
- ↳ Mavic Air
- ↳ Mavic Air 2
- ↳ Mavic Air mini
- ↳ Sparc
- ↳ Phantom 4
- ↳ Inspire 2
- ↳ Andere
- andere Hersteller und Modelle sowie selbstgebaute Kopter
- ↳ Eigene Konstruktionen - Selbstgebaut
- ↳ andere Hersteller & Modelle
- Allgemeiner Bereich
- ↳ Benutzervorstellung
- ↳ Treffen und Veranstaltungen
- ↳ Raum Plz 0
- ↳ Raum Plz 1
- ↳ Raum Plz 2
- ↳ Raum Plz 3
- ↳ Raum Plz 4
- ↳ Raum Plz 5
- ↳ Raum Plz 6
- ↳ Raum Plz 7
- ↳ Raum Plz 8
- ↳ Raum Plz 9
- ↳ Österreich
- ↳ Schweiz
- ↳ Andere Länder
- ↳ Klatsch und Tratsch
- ↳ Mit demKopter aufgenommen - Fotos
- ↳ Mit dem Kopter aufgenommen - Filme
- ↳ Pressespiegel
- Fachsimpeln
- ↳ Gesetze und Vorschriften
- Technik
- ↳ Flug Kontroller ( FC )
- ↳ DJI Naza
- ↳ DJI A2
- ↳ DJI A3
- ↳ DJI Wookong
- ↳ SP Racing F3 & F4 mit Cleanflight / Betaflight
- ↳ DJI Motoren Set's - Antriebssysteme E300, E305, E310, E800 etc.
- ↳ Technik allgemein, was nirgendwo anders passt.
- ↳ Antennen Technik
- ↳ FPV
- Kopter Schulung
- Marktplatz - Angebote von Usern
- ↳ Anleitung - Regeln - Hinweise
- ↳ 3D Drucke
- ↳ Kopter - Kopter Bausätze
- ↳ Kopter Zubehör - Ersatzteile
- ↳ Stromversorgung Ladegeräte / Batterien
- ↳ Fernsteuer Sender / Empfänger
- ↳ Auftragsflüge (gewerblich)
- ↳ Sonstiges
- THW OV Viersen
